Dear,
In one of fin fan air cooler, many of Tubes are found bend (Top side only) may be due to thermal expansion and or may be due to tube sheet restriction so please advise your recommendation on this. And also some vibration is noticed in Louvers.
Design code : ASME SEC VIII DIV.1 + API 661
Design Temp tube side : 310/149 deg C
Operating Tube side temp: 140 / 60 deg C
no of bay/unit : 3
Draft forced
Fluid circulated: LCGO
Design Pressure: 34.2 barg +HV
Operating Pressure in : 20 barg
Please provide your opinion about probable causes and recommendation
Thank you,
Sameer
Fin Fan Air Cooler
Started by sameercnn, Mar 28 2017 06:43 AM
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Air-Cooler Heat Exchanger - Unit Vs BayStarted by Guest_pymorty_* , 19 Dec 2023 |
Dry Cooler Vs Cooling TowerStarted by Guest_Quimarah_* , 10 Sep 2023 |
Air Cooler Fan ShutdownStarted by Guest_A.D._* , 13 Oct 2021 |
![]() One Air Cooler Instead Of TwoStarted by Guest_Movers_* , 30 Sep 2021 |
