Does anyone have excel about this?
http://www.cheresour...d-fittings?pg=6
IS APPLICABLE FOR STEAM AND STEAM CONDENSATION PIPING?
Posted 29 March 2017 - 09:38 PM
Posted 30 March 2017 - 10:28 AM
Rodrigo:
What are you trying to request? Your query is unclear and unspecific.
Please be specific. As engineers, we can solve a lot of problems, but we can't read minds --- yet.
Posted 30 March 2017 - 07:43 PM
Ok..I'm sorry for not being clear!
Answer:
Are you trying to calculate the pressure drop in steam and condensate piping?
Yes.
Are you requesting a spreadsheet program to do these calculations?
Yes.
Are you asking if Equivalent Piping lengths can be used for fittings and valves when doing these calculations?
Yes...for this case...steam and Water condensate (condensate return to Steam Boiler).
Yes...in case for steam and con
Thank you very much!
Rodrigo Franco
Posted 31 March 2017 - 07:40 PM
http://www.spiraxsar...Pages/home.aspx
Let you consider this resource to support your work.
Have fun .
Posted 01 April 2017 - 11:53 AM
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
Relieving Flow Rate In Terms Of Air EquivalentStarted by Guest_go-fish_* , 21 Nov 2024 |
Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
Pressure Regulators Vs Control ValvesStarted by Guest_panoska_* , 19 Jun 2024 |
