Sulphur Recovery Unit
Posted 17 April 2017 - 12:49 PM
Posted 17 April 2017 - 02:12 PM
Paty:
Please be specific. Do you want to produce elemental sulfur (as in a Claus Process)? Or do you want to simply remove the acid gas from your feed mixture and produce a sulfur-free hydrocarbon stream? Or perhaps you require the latter, and feel that you must accept the former.
What is your basic Scope of Work?
Is this a real-life project, or an academic assignment? Have you already looked at, and evaluated, some processes?
Posted 18 April 2017 - 11:54 PM
Paty.,
As I have known before., Gas Processing Plant have Biological Sulphur Recovery unit ( BSRU ). At these unit, Acid Gas come from Acid Gas Recovery unit ( AGRU ) separated H2S to become Sulphur pellet. We putted Bioreactor to consume H2S with bacteria and made it to slurry. These slurry are flow to Sulphur Solidification& Bagging Unit.
Posted 21 April 2017 - 11:10 PM
my 2 cents....
it seems an academic / over simplified exercise....
the gas is too rich in HCs to be directly sent to an SRU (Claus). a further step of enrichment (AGRU) is requested upstream of the SRU.
the most used technology for SRU is Claus, not the bio processes. there are other options (eg LoCat, production of H2SO4 instead of S, etc)
depending from the orign, usually the gas is contaminated by some of the following materials: water, ammonia, CO2, COS, HCN, amines,,,,the level of these contaminants are decisive to select the right process configuration.
also important is the required recovery of H2S, under the emissions / air quality point of view
I suggest to consult the book "Kohl, Nielsen, Gas Purification"
good luck!
Edited by gegio1960, 21 April 2017 - 11:22 PM.
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Today, 08:17 AM |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
