Hi all,
I need help on the following.
I have a vacuum column run with overhead pressure of (100-300mbar) and the temperature is high enough (> 130-150C) to generate low pressure steam. I want to use a steam generator-condenser to recover the overheads heat(to generate low pressure steam) which is currently being just rejected.
for similar applications in other columns which are being run at atmospheric or higher pressure I have seen kettle type condensers being used.
Will such a heat exchanger type work here? aspen EDR simulation indicated acceptable pressure drop (<10%)
when couple of kettles are used in parallel. But I am wondering if something more advanced like plate exchangers can be used and if so, how can they be simulated? will the large volumes handled(because of low pressure) be an issue?
any useful references on type of proven condenser-steam generators to be used for such applications are welcome
