Hi everyone, i have some problemes that need your help.
i have to simulate a pre-heat train from an existing unit, this train (the first part ) is composed from 6 exchanger devided in 3 exchanger in serie ( 3X2 ) as showed in the picture E101A to F : crude pre heat train picture), and it's associated with the heater DATA SHEET,
the datasheet show the the crude is heated from 80°F to 220°F (tube side), and the Reflux circu de tete (top stage pump around draw) from 240°F to 150°F shell side, my questions are:
1- what is the meaning of :SURFACE PER UNIT (25000 sq.ft), and shells per unit:6 in datasheet.
2- the heat exchanger-BTU/hr (52500000) showed in the data sheet represent the total energie of the 6 exchanger or only for one.
3-the datasheet don't give us the details of the temperature of each exchanger parameter, especially the inlet and the outlet of eachone.
4- when i try to simlulate the train in hysys (also with EDR) i get some errors like, Ft correction very low(i know what that mean), or i get the 220°F in the first exchanger and not in the last one.
NB: for the excel file, actually it's an hysys file, click on open with and select hysys program.
i'm ready for any clarification and for your help. thank you.
Edited by titim, 31 July 2017 - 07:21 AM.
