Can any body explain about shape of Amine CO2 absorber and Stripper why like Coca cola bottle ??
Riaz
Posted 31 July 2017 - 06:21 AM
Riaz
Posted 31 July 2017 - 10:27 AM
Riaz:
................that amine absorbers and strippers have the shape of a coca-cola bottle?
Submit some photos if you have any.
Posted 07 August 2017 - 06:24 AM
Riaz:
- Who told you?
- Where did you see this?
- Where did you read this?
- How do you know?
Dear Sir,
Our Plant is BASF aMDEA for CO2 Removal in Ammonia Synthesis Plant, where Amine absorber shape is line coca cola bottle, where as I saw Stripper shape reverse of absorber shape in Hot Potassium for CO2 removal in batchel technology......actually I want to secret behind the shape, I am attaching photo too
Posted 08 August 2017 - 07:56 AM
Returning both lean and semi-lean streams to the absorber is a method to save steam. The minimum diameter of a distillation column is set during the design based on internal hydraulics. Sometimes there is an economic benefit to having two diameters in one column to reduce the amount of metal used in fabrication.
Posted 14 November 2017 - 11:08 PM
using 2 different diameter is to maintain the pressure. as the co2 get absorb to the solvent it will reduce the pressure of the gas. reduce the volume of the column will maintain the pressure.
Posted 14 November 2017 - 11:11 PM
and for information not every stripper or absorber always shape like that. I have seen stripper just like a regular vessel
Scrubber(Absorber) In Apsen PlusStarted by Guest_Seonwoo_* , 20 Mar 2025 |
Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
Hcl Fume AbsorberStarted by Guest_Chemeng40_* , 15 Oct 2024 |
Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Absorber Tower Can't Be ConvergedStarted by Guest_dynamichysys_* , 14 Jun 2024 |
