why gasoil is used directly as a diesel fuel ?
why it doesn't require the proceesing like gasoline?
thank you
Posted 01 August 2017 - 12:45 PM
thank you
Posted 01 August 2017 - 09:28 PM
Posted 03 August 2017 - 08:48 AM
Posted 13 November 2017 - 10:50 PM
This is usually an issue of not being familiar with stream names. Gas oil (note space) is the cut heavier than diesel and lighter than residue. It is typically fed to FCC or hydrocracking units. Gasoil (no space) is what diesel fuel is called in some regions. Same as U.S. diesel except for diesel index spec. Gasoil does have a wider boiling range in some regions than does U.S. diesel fuel, however, and that leads to the confusion.
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Green Diesel StorageStarted by Guest_Lucianaa_* , 16 Feb 2024 |
Diesel Composition For Hx DesignStarted by Guest_ganeshrbhat_* , 05 May 2023 |
Hydrogen Fuel CellStarted by Guest_rednaxela_* , 09 Mar 2023 |
