My research project involves characterising a botanical material(dry seed pods of Hura crepitans) as random packings. I don't know any means of determining the surface area since the material is not regular. I would appreciate any helpful suggestions.
images.jpg 7.66KB
0 downloads
Surface Area Determination
Started by etukjoshua, Aug 05 2017 11:48 PM
Posted 05 August 2017 - 11:48 PM
Posted 06 August 2017 - 10:15 PM
I might try to spray the pods with adhesive, then coat them with fine sand. Measure the amount of sand by weight difference. Then compare the amount of sand that sticks to a flat surface of known area to determine the pod surface area.
Posted 07 August 2017 - 09:45 AM
Is this a standard method? I am using the results for an academic research work.
Posted 08 August 2017 - 07:48 AM
The details of the sand method of surface area measurement have not yet been published by the International Pod Scientific Institute, so you should verify its accuracy in your research. Perhaps ping pong balls or other regular 3-D shapes could be used as controls instead of a flat shape. Determine surface area of the balls by mensuration. The surface area should not change if the balls are dented or deformed so these could still serve as a known surface area for comparison. For the average surface area of non-uniform pods, I think the inherent variability in the sand method will be outweighed by the variability between pods. Good luck on your research and I hope your work leads to great success. The Pilesar-etokjoshua pod measurement method may make us both famous one day!
Posted 09 August 2017 - 12:26 AM
Thank you sir. I hope so too
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
Screw Compressor Suction Pressure DeterminationStarted by Guest_Deicide Dunkelheit_* , 22 Jan 2025 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
![]() Ways To Reduce Wetted Surface Area In Psv SizingStarted by Guest_KoreaGyu_* , 21 Aug 2024 |
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
