dear sirs,
We are planning to replace tube bundle for Fin fan cooler and there is no changes in design but tubes are corroded so we want to replace complete bundle. Please advise me U & R stamps are required?
Posted 06 September 2017 - 01:15 AM
Hi Sameercnn
As per my understanding, U Stamp is the ceritification for the new equipment while R Stamp is the certification for the repaired equipment which has ever certified by an existing stamp. So, for the case of new bundle, U stamp should be applied.
Anyway, i think the manufacturers can answer your question as they have passed a lot of certifying processes on their equipment.
![]() Air-Cooler Heat Exchanger - Unit Vs BayStarted by Guest_pymorty_* , 19 Dec 2023 |
Dry Cooler Vs Cooling TowerStarted by Guest_Quimarah_* , 10 Sep 2023 |
Air Cooler Fan ShutdownStarted by Guest_A.D._* , 13 Oct 2021 |
![]() One Air Cooler Instead Of TwoStarted by Guest_Movers_* , 30 Sep 2021 |
Corrosion Under Deposition At Trim Cooler Of Rfcc Main Fractionator OvStarted by Guest_Eric Nguyen_* , 19 Jul 2021 |
