hello
i want to know what effect of Non-standard Reid vapor pressure (very low or very high value of TVR) of gasoline in engines.
thanks
Posted 30 August 2017 - 12:11 PM
hello
thanks
Posted 30 August 2017 - 10:47 PM
You can think of Reid Vapor Pressure (RVP) as a measurement of C4. Mixing butanes into gasoline can help improve many of the parameters that gasoline is measured by. However, the butanes tend to vaporize, with the fuel remaining in the liquid state changing character and perhaps no longer meeting specifications. The RVP spec is designed so that the fuel buyers are not tricked by the fuel sellers into purchasing what is essentially off-spec gasoline mixed with butanes. You can estimate the amount of butanes in the gasoline directly from the RVP reading. For example, if the fuel has an RVP of 4 psi, you can estimate there is about 4% C4 in the fuel. I think there is usually not a minimum RVP spec for fuel -- only a maximum RVP allowed. The fuel behavior in the engine is better characterized by Research Octane Number (RON) and Motor Octane Number (MON). If the RON and MON are the same for two fuels, the engine will not be affected if the fuels have a different RVP.
Posted 02 September 2017 - 04:10 AM
thank you
in our refinery when making gasoline and verifying compliance, several analyzes must be performed such as
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
