Compressible Flow Query
compressible flow fluid dynamics perrys
#1 gmcgough600
gmcgough600
  • 7 posts
Posted 10 October 2017 - 10:02 AM
I'm trying to set-up a spreadsheet to do compressible flow calculations based on Perry's (Adiabatic Flow with Friction in a Duct of Constant Cross Section) but I'm not sure which value I should use for the isentropic index k in equation 6-120 (easy to use k at inlet conditions but this will be different from the average). If I was dealing with air I would simply use 1.4 but I'm dealing with natural gas which seems to vary a lot more with conditions.
I have attached an extract outlining this approach, Example 8 is useful but this is for air. Any advice appreciated.
#2 Bobby Strain
Posted 10 October 2017 - 10:57 AM
I always use isothermal flow to simplify calculations. Results are usually close enough. You might want to search this site and you may find lots of spreadsheets. Or online. Harvey Wilson (Katmar) has some reliable, inexpensive software. If you are looking at long pipelines, you should consider other correlations.
#3 latexman
  • 1,928 posts
Posted 10 October 2017 - 12:01 PM
Crane TP410 gives k = 1.27 for natural gas.
P.S. No extract attached.
