I have a question, is it possible to design a heat exchanger deals with many inlet temperatures, I mean by this I need a constant outlet temperature (for example 40 °c), but the inlet temperature varies (it could take different values 10 °c or 20 °c).
If it is possible, how could we control this issue?
Your quick response is highly appreciated.
Multi Inlet Temperatures In A Heat Exchanger
Started by Sham85, Oct 13 2017 10:31 PM
No replies to this topic
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
