Why Hysys Isn't Providing Proper Steam Properties
hysys steam
9 replies to this topic
#1 IonCube
IonCube
  • 62 posts
Posted 18 October 2017 - 10:23 AM
The image says it all. One can observe enthalpy values kJ/kg of HYSYS are a total mismatch when compared with two of my trusted JAVA calculators
In the screenshot a portion of propeties (HYSYS) is shown where I have used (as Inputs) Vapour Fraction, Molar flowrate, Pressure & lastly the composition which is only H2O
HYSYS do calculate Saturated Temperature correctly, have also checked specific volume but why not enthalpy or am I missing something?
#2 latexman
  • 1,924 posts
Posted 18 October 2017 - 10:38 AM
Attachment did not open for me.
#3 IonCube
IonCube
  • 62 posts
Posted 18 October 2017 - 12:38 PM
I am sorry I had hotlinked the image ...now its added as attachment
Edited by IonCube, 18 October 2017 - 12:39 PM.
#4 Bobby Strain
Posted 18 October 2017 - 12:54 PM
Have you checked HYSYS values using the HYSYS ASME properties for your model? And, we don't know anything about your favorite JAVA calculators. You should reference one of the widely accepted standards for steam/water properties
#5 Pilesar
  • 1,691 posts
Posted 18 October 2017 - 01:04 PM
It is not the absolute value of enthalpy that matters. It is the change in enthalpy from one process condition to the other. Not all enthalpy scales use the same reference basis.
#6 latexman
  • 1,924 posts
Posted 18 October 2017 - 01:12 PM
That does look strange.  Is it a reference difference between the different methods?  Can you make HYSYS condense the stream and see what it says for the latent heat of vaporization?  That will subtract out the reference within that thermo model.
The HYSYS value appears to be almost exactly a factor of 5 higher than the other two.  Does that mean anything to you?
#7 IonCube
IonCube
  • 62 posts
Posted 18 October 2017 - 04:27 PM
In a short sentence they are trusted ..values of specific vol. ,temps ...match with what HYSYS calculate  secondly as a redundancy I have used two calculators!
I haven't attached this stream to anything, out of intuition I have just added single Material Stream. This is from HYSYS xml
Component Lists
Property Name Property Value Status or Type
ComponentListName Component List - 1 Specified
ElectrolyteList 1 Specified
ComponentName H2O Specified
ComponentType PureCompObject Specified
Reaction Package
NumberOfReactions 0 Specified
NumberOfReactionSets 1 Specified
ReactionSetName Global Rxn Set Specified
SetType Unknown Specified
SetSolver FEMPTY Specified
NumberOfActiveRxns 0 Specified
NumberOfInactiveRxns 0 Specified
VolumeContinuation False Specified
InitialVolumeFraction 1e-006 Specified
NumberOfSteps 10 Specified
TraceLevel 0 Specified
PreviousSolutionAsEstimates True Specified
UsePreviousTempAsAdiaEst True Specified
IEGDampingFactor 1 Specified
IEGTolerance 0.001 Specified
SolverMaximumIterations 200 Specified
SolverTolerance 1e-005 Specified
Fluid Packages
FluidPackageName Basis-1 Specified
FluidPackageType PengRobObject Specified
ComponentList Component List - 1 Specified
IsComThermo False Specified
PropPackage Peng-Robinson Specified
EOSEnthalpyMethodSpecs EOS Specified
Component H2O Specified
TreatmentofInteractionCoefficients False Specified
UseEOSLiquidDensity False Specified
SmoothLiquidDensity True Specified
EstimationMethod UNIFAC VLE Specified
TryIOFlashFirst False Specified
UseMultiPhaseFlash False Specified
Deleted True Specified
AverageOfExisting False Specified
IdealGas False Specified
WilsonsEquation True Specified
MaximumStagesAllowed 3 Specified
StabilityTestMethod Low Level Specified
PhaseSortMethod Use Phase Type and Density Specified
please refer to the XML above. Heat of vaporization (2325 versus ~2305 ) does match ...also the specific volume (HYSYS gives 58.66m^3/kgmol then divide by 18.02 its the same as my calculators) see the attachment
Edited by IonCube, 18 October 2017 - 04:28 PM.
#8 Saml
Saml
  • 301 posts
Posted 18 October 2017 - 06:11 PM   Best Answer
As far as I know the enthalphy in Aspen and Hysys is referred to the pure components at reference T and P (so it would be the reference to Oxygen and Hydrogen). It is done this way to account for heat of reaction where there are reactions.
Your Steam table use liquid water 0°C as the zero so the value of 2645 kJ/kg
Hysys use the enthalphy with the zero set  to oxygen and hydrogen in reference condition.
So Heat of Formation of Water at 25 °C (Liquid)
-285 kJ/mol = -15833 kJ/kg
Delta H to go from 25°C and bar to your condition = 2540 kJ/Kg
Net = 13293, very close to the 13270 that Hysys is reporting
The heat evolved in any transition should be correct.
By the way, IAPWS or Steam Tables are better methods than Peng Robinson or UNIFAC when you have only water .
#9 pavanayi
pavanayi
  • 258 posts
Posted 19 October 2017 - 02:30 AM
Echo ing what has been said above,
PR is not a good option in your case. If it is only H2O, then I would go for NBS Steam.
Also, absolute enthalpy values vs. delta enthalpy values have been been discussed a few times in the past in these forums.
Just to add, if you are interested, you can check the reference basis for enthalpy calculations in Hysys on their support centre (search article ID 000042545). If I am not mistaken, it is also covered in the simulation basis reference.
#10 serra
serra
  • 311 posts
Posted 19 October 2017 - 03:20 AM
yes, there are many discussions at cheresources, see for example :
https://www.cheresou...ation-packages/
some software allow to redefine base values but starting from heat of formation is useful for solving reactions, see a example about how this works and how different base values can affect results (it's for prode, but the same for aspen),
https://www.cheresou...ences-in-prode/
