1
Carbon Mol. Seive Mechanical Properties
#1 Ranga v
Ranga v
  • 35 posts
Posted 31 May 2026 - 10:13 AM
Dear forum members:
Nitrogen is generated by passing compressed air in a pressure swing adsorption cycle. The adsorbent used is Carbon Mol. seive. Mechanical tests, namely Crush strength and Hardness, are required to check its performance.
Requested members to share the standard test methods document.
  • 7,062 posts
Posted 31 May 2026 - 06:11 PM
Attached a specification sheet from Calgon.
A google search should help you to find out the methods. ASTM methods are available.
D3802 and D5231
Good luck,
#3 Ranga v
Ranga v
  • 35 posts
Posted 31 May 2026 - 10:05 PM
