3
Adsorption On Activated Carbon
#1 guoyinyanliner
guoyinyanliner
  • 97 posts
Posted 20 October 2026 - 08:02 AM
Heavy Hydrocarbon Adsorption on Activated Carbon: Bed Sizing and Pressure Drop Calculation
  • 7,071 posts
Posted 20 October 2026 - 08:18 AM
To support your work.
Famous equation for pressure drop is Ergun equation. (Doc attached)
Note: You should know how expensive it is to dispose AC in China.
Note 2: Be aware of self-ignition of AC bed saturated with organics
BTW, we have no indication about the flowrates, are we talking about gas or liquid, what are your heavy hydrocarbons?
With so little information no meaningful answer.
EDIT:
Because you are in China, talk to the reference underneath:
How to Calculate Activated Carbon Fill Volume for VOCs Treatment | Industrial VOC Guide
#3 guoyinyanliner
guoyinyanliner
  • 97 posts
Posted 21 October 2026 - 11:54 PM
EDIT:
The document you gave me does not include any examples of adsorption calculations
#4 breizh
  • 7,071 posts
Posted 22 October 2026 - 12:38 AM
are you sure? you got a excel sheet and document about design. Should suffice?
#5 latexman
  • 1,941 posts
Posted 22 October 2026 - 05:44 AM
guoyinyanliner,
Try this, copy/paste your original post into Google AI, Claude, or ChatGPT, and look what it says.  I modified your OP slightly to be more precise, "Heavy Hydrocarbon Adsorption on Activated Carbon: show me detailed calculations for Bed height and diameter Sizing and Pressure Drop Calculation."  If you give AI your data it will size it for you.
Just remember, AI can make mistakes!
Here's a link to what I did/got: https://share.google...xm3sApptPXkyZBV
#6 AsherMuse
AsherMuse
  • 14 posts
Posted 17 November 2026 - 01:58 AM
For a bed like this I would not start from a spreadsheet - I would start from the duty, because bed size and pressure drop both follow from it: gas or liquid, flow rate, temperature and pressure, what the heavy hydrocarbon is and its inlet concentration, the target outlet concentration and breakthrough time, and how the bed is regenerated or replaced. Without those, Ergun can only give a pressure drop for a guessed velocity, particle size and voidage, so any number is not checkable.
Two things that are often missed in the sizing itself. First, quote the pressure drop for normal operation and for the upset case - fines migration, channelling or a partially blocked distributor can push it well above the clean-bed value, so the vessel and downstream equipment need to be checked against that, not just the clean value. Second, the bed needs a retaining/support screen at the outlet, and a support grid underneath, and that screen has to be specified as a system, not just by aperture: for example, 316L plain weave, 2.0 mm aperture +/-0.2 mm, 0.5-0.7 mm wire diameter, minimum open area 56% or more, grade included. A fine woven mesh on its own will deform under pressure - it needs a perforated support cylinder or plate behind it.
If you can share the flow rate, phase, inlet concentration and required breakthrough time, the bed diameter, depth and Ergun pressure drop can be worked out properly.
