hi!!!!!!!!!!!
Can We Use Thermocol as a insulation For Propane Compressor Loop, Which Uses Synthetic Oil As Lubricant And It Compress The Propane(Closed Loop).
Intially the insulation material is poly urethyene fibre (PUF), after shutdown we are trying to replace with thermocol,
whether it will work or not??
Pls Comment
