Dear Respected Members
I would like to seek expert advise / suggestions on the following issue.
we had nitrogen gas depressurization system where nitrogen gas is depressurizing via scrubber vessel to ATM. in the system PCV ( self actuated pressure control valve ) is installed to limit the downstream pressure @ 0.5 bar g. total time for depressurization operation is considered as 30 min which is confirmed by client. Upstream pressure at PCV is 5 bar g which is varying as the operation progress. ( process Conditions that is pressure and flow rate of Nitrogen gas is varying ) .
with the current design of PCV , IT Takes almost 3.5 to 4 hours to get operation completed. what is the reason to cause this problem?
I am again doing resizing of the PCV but not able to reach best possible solution .
whether we have to go for control valve ( Modulating type ) to overcome this problem or with already installed valve whether by doing internal modification we can achieve our target .
Awaiting for your valuable suggestion.
regards
VP
