I am doing adequacy check calculation on a PSV on a de-ethaniser overhead receiver for an existing facility(see sketch attached). The overhead from the de-ethaniser goes to a condenser and then to a receiver vessel. The vapor outlet from the receiver goes to the fuel gas header and the liquid is full reflux to the de-ethaniser. The column overhead has a PSV set at same pressure as the PSV on the receiver. Based on my understanding, I am considering the following as credible relief scenarios:
1. External Fire
2. Blocked vapour outlet
3. Loss of reflux due to blocked liquid outlet as column PSV already accounts for reflux failure.
I have calculated relief load for the fire case. I am not really sure for the relief load calculations for blocked vapour outlet. Should I take relief load as the normal flow through the control valve at relieving conditions and use vapour sizing equation to come up with the orifice size?
Edited by go-fish, 03 January 2018 - 09:52 AM.
