Sour Water Stripping Without Heat Input
sour water without heat stripping
#1 Ailia
Ailia
  • 3 posts
Posted 29 March 2018 - 02:15 AM
I want to simulate a sour water stripper to remove H2S only from produced water. My stripped water specs are not stringent. I simulated the case in Unisim using Sour Peng Robinson property package. I used a simple absorber unit operation and stripped the water with available fuel gas without adding any heat. The column converged and shows satisfactory results.
My question is that are there actual sour water strippers without using heat input (reboiled or steam stripped)?
Will simple cold fuel gas stripping reduce the amount of H2S in water?
  • 1,639 posts
Posted 29 March 2018 - 08:47 AM
'Yes' to both your questions.
#3 Ailia
Ailia
  • 3 posts
Posted 01 April 2018 - 01:36 AM
Thanks for the reply Pilesar.
My plant's sour water is stinking the open API separator area. Is there some info that tells me how low should be H2S content in water to stop smelling?
#4 Technical Bard
Technical Bard
  • 407 posts
Posted 01 April 2018 - 09:07 AM
H2S has an odour at sub-ppm levels in air.  A hot sour water stripper might get the concentration in the water down to 20 or 30 ppmw, and it will still exert a partial pressure (very difficult to make stripped sour water not smell).
Adding a chemical to either shift the pH up (shifting the H2S to sulfide ions), for instance, caustic (NaOH), or adding an oxidizer (H2O2) to turn sulfides to sulfates. will stop the smells.
#5 Ailia
Ailia
  • 3 posts
Posted 03 April 2018 - 02:53 AM
Thanks a million
This is what I was looking for  :rolleyes:
