Hello for ALL
When i do a simulation of a distillation column, how can I use the cold feed stream as a coolant to OVHD condenser within the same file in Aspen Hysys or I can not ?
Thank you in progress..
Posted 29 March 2018 - 11:30 AM
Hello for ALL
Posted 29 March 2018 - 02:21 PM
Use your imagination. But keep it simple. Don't use a heat exchanger. Use a heater and separate cooler. And duplicate streams.
Posted 30 March 2018 - 05:23 AM
Thank you very much, I did a copy of streams and do it separatly. My question : is there a procedure to do it within the distillation column, in another word to make it like the actual process flow diagram?
Posted 30 March 2018 - 10:04 AM
You can use a heat exchanger to do this, but the solver may struggle with the solution. You need to open the column subflowsheet and replace the condenser with a heat exchanger. Then, you connect the feed stream and feed return stream to the column, and in the column subflowsheet connect those to the overhead condenser exchanger.
Posted 31 March 2018 - 02:43 AM
Thank you very much I will do this try and tell you.
Posted 01 April 2018 - 12:12 AM
Engeng,
As mentioned by Bobby, if you model the tower and the condenser as separate blocks, then you create an unnecessary recycle loop. This can lead to convergence issues. I would suggest the following:
- Model the column including the condenser
- Create a pseudo-stream of vapor from Stage 2
- Use this pseudo-stream to model the exchanger
Hope this help,
Abhishek
Posted 28 April 2018 - 01:59 PM
Thank you very much for all
Surface Condenser (Htri)Started by Guest_Prim_* , 08 Apr 2026 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
