While I was performing HYSYS simulation for dense phase methane rich gas of following composition I could notice some results that contradicting my understanding as explained below
Composition of natural gas
Case1:
Methane- 0.8970
Ethane- .0950
Nitrogen- 0.080
Pressure: 1900 psig
Temperature-55F
Case 2:
Methane- 0.8955
Ethane- .0948
Nitrogen- 0.080
Water- 0.0016
Pressure: 1900 psig
Temperature-55F
When simulated
The following properties obtained same for both cases:
Critical Pressure- 827.8psig
Critical Temperature- -83.55F
Cricondenbar- 836.3psig
Cricondentherm- -76.4F
My questions are:
1.I observed that Even though the properties and phase envelope suggests that its a dense gas operating well above cricondenbar and cricondentherm , I found at the operating pressure(1900 psig) gas becomes liquid at -approximately -34F in both cases and in case2 where water present(critical properties are still same! ) the water starts to drop out even at approximately +125F.(by trial and error method)
My understanding from the envelope is, above criconedtherm and cricondenbar the gas should not be liquidized. Butt using HYSYS((by trialand error method) stil I coud find temperature above cricondentherm where gas becomes liquid which contradicts my genral undrstanding.
Now I dont know where I went wrong in analysing!
2.In both cases critical properties are still same! but I assume that this is because only small change in composition. Am I correct?
I request expert to show some light on this regard
Thanks in advance.
Methane- 0.8970
