3
Natural Gas Pre-Cooling Unit
#1 guoyinyanliner
guoyinyanliner
  • 85 posts
Posted 18 September 2026 - 08:22 AM
​This is a natural gas molecular sieve dehydration process, and the red arrow points to a natural gas pre-cooling unit. Could you please specify what exact equipment this is? I haven't used this type of equipment before.
Edited by guoyinyanliner, 18 September 2026 - 08:22 AM.
  • 1,696 posts
Posted 18 September 2026 - 11:46 AM
I do not see that you were successful in posting anything but text. But from your text description, a pre-cooling unit before natural gas dehydration is likely to be for the purpose of condensing moisture from the gas and will consist of a heat exchanger and a 2-phase separator. Any water removed from the stream prior to the mole sieve reduces the load on the sieve.
#3 breizh
  • 7,062 posts
Posted 19 September 2026 - 05:38 AM
Google search AI mode
A natural gas precooling unit is a piece of process equipment used to lower the temperature of natural gas before it enters a downstream treatment, liquefaction, compression, or separation process.
Why is natural gas precooled?
Precooling helps by:
  • Removing heavier hydrocarbons (such as propane, butane, and condensates)
  • Reducing water vapor content and preventing hydrate formation
  • Lowering compression power requirements
  • Improving efficiency of LNG (Liquefied Natural Gas) plants
  • Protecting downstream equipment from temperature and phase-change issues
How does it work?
Typically, the incoming gas passes through a heat exchanger where it is cooled by a refrigeration system or another cold process stream.
Common precooling methods include:
  1. Propane refrigeration systems
    • Widely used in LNG facilities.
    • Gas may be cooled from ambient temperature to around -30°C to -40°C.
  2. Mechanical refrigeration
    • Uses refrigerants such as propane, ethylene, or mixed refrigerants.
  3. Heat exchange with cold process streams
    • Recovers cooling from existing plant operations.
Example in an LNG plant
In a typical LNG facility:
Natural Gas Feed
Precooling Unit
Acid Gas Removal
Dehydration
Liquefaction Unit
LNG Storage
Or, in many modern LNG processes:
Feed Gas
Treatment
Propane Precooling
Main Cryogenic Heat Exchanger
Liquefaction (-162°C)
The precooling stage removes heat efficiently before the gas enters the much colder and more energy-intensive liquefaction section.
Main equipment in a precooling unit
  • Heat exchangers
  • Refrigerant compressors
  • Refrigerant condensers
  • Refrigerant separators/drums
  • Control valves and instrumentation
Industries that use precooling units
  • LNG export terminals
  • Gas processing plants
  • Petrochemical facilities
  • Natural gas storage and transportation systems
In short, a natural gas precooling unit is an upstream refrigeration section that cools natural gas before deeper processing or liquefaction, improving efficiency and enabling the removal of unwanted components.
