We are implementing a purge gas system for an existing flare header. Has anyone used oxygen analyzers upstream of the gas seal at the flare stack instead of pressure transmitters to activate supplemental purge for special events (rainstorm, etc). Also, if you have had experience with the above, what challenges did you face putting this in service with an existing flare header. We plan to put the purge gas system in service while the flare is operational, after we've completed a "sweep".
Purge Gas For Flare Header
Started by Motrack, May 09 2018 03:33 PM
No replies to this topic
Posted 09 May 2018 - 03:33 PM
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
![]() Flare And Venting SystemStarted by Guest_miz19_* , 10 Jul 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
