Performance Gear Pump
gear pump maximum rpm pump
#1 thomas.yoga
thomas.yoga
  • 4 posts
Posted 08 June 2018 - 01:30 AM
Hi there,
I want to ask one thing about gear pump. If the maximum speed is 500 RPM and motor was 700 RPM, what will happen?
I mean if I using the motor RPM speed is faster than the maximum RPM speed of gear pump, is it safe?
Thank you so much,
Best regards,
Thomas
#2 thorium90
thorium90
  • 1,073 posts
Posted 08 June 2018 - 02:02 AM
Is there a gear box or a belt system being used to reduce the speed?
Edited by thorium90, 08 June 2018 - 02:03 AM.
#3 thomas.yoga
thomas.yoga
  • 4 posts
Posted 08 June 2018 - 02:25 AM
I just want to know what the effect if the pump rotate over maximum RPM. Please help according your experience.
Edited by thomas.yoga, 08 June 2018 - 02:26 AM.
#4 breizh
  • 7,051 posts
Posted 08 June 2018 - 04:01 AM
http://www.northern-...2 Lesson 1 .pdf
hi ,
I believe you will go to mechanical failure by damaging the gear .
Consider the doc attached to support your work , definitely good to call the vendor .
#5 Art Montemayor
Posted 08 June 2018 - 11:46 AM
Thomas:
I understand you want to know what will be the effects of running a gear pump 40% greater than its rated rpm.  Your question is vague in that you don't tell us WHAT fluid you are pumping and under what CONDITIONS.  I have operated gear pumps - such as the Northern model that Breizh has given you information on - well over 25% capacity.  But that was on hydraulic applications - pumping oil at 100 oF and 2,500 psig discharge.  The fluid was a self-lubricating one and Northern had no problems in approving the operation.
You also haven't told us what TYPE of gear pump you are dealing with.  There are several types of these positive displacement pumps and it makes a marked difference.  Whatever our Forum comments may be, rest assured that we would always warn you not to exceed the manufacturer's recommended loadings on the pump without consulting with the manufacturer (not the sales representative or distributor).
