Co2 Loading In Amine Scrubbing
Started by Aziii, Jul 10 2018 02:35 PM
Posted 10 July 2018 - 02:35 PM
Hi
I would like to simulate co2 absorption with 30% wt MEA in aspen hysys but i have some problems.
I dont have any information about solvent flow or number of stages and i should calculate them.
I need equilibrium data, right?
I found the equilibrium solubility of CO2 in 30% wt MEA at 40°C, but the data are on CO2 loading that means mol co2/mol MEA, not X in equilibrium curve (X means mole ratio of solute to solut-free absorbent in the liquid).
How i can solve that?
Could you help me please?
Posted 11 July 2018 - 02:05 AM
Right, but in order to build curve in addition to mol CO2/mol MEA you should have partial pressure of CO2 in each data point.
Nikolai
Posted 11 July 2018 - 04:16 AM
Thank you so much for your answer.
Yes, all data that i found are based on partial pressure of CO2 VS CO2 loading.
For calculating minimum absorbent flow, i need Y Vs X diagram.
I can calculate y and then Y from partial pressure but i dont know how to calculate X from co2 loading
Posted 11 July 2018 - 09:07 PM
You need take assumption about composition MEA solution that include (MEA, CO2, H2O....) by weight and go to mol via m/Mr. If you know mol CO2/mol MEA you can define mole CO2 in MEA solution (X).
Posted 13 July 2018 - 08:16 PM
Difine number state by real plate or number section packing. Then supply detail configuration of tower because with amine system , hysys use detail configuration of tower to calculate
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Dp Drop In Structured Packing Amine Absorber Causing IssuesStarted by Guest_kek12345_* , 10 May 2024 |
![]() Amine System FiltrationStarted by Guest_Hanaa_* , 09 Jan 2022 |
Caustic Tower - Acid Gas ScrubbingStarted by Guest_rachalex4_* , 05 Dec 2022 |
