Cooling Utilities
process design heat exchanger rule of thumbs heat integration utilities
#1 panoskagiou
panoskagiou
  • 103 posts
Posted 21 July 2018 - 03:12 AM
Hello everyone!
I would like to ask you about cooling utilities:
Generally cooling water is used when you want to cool a stream to around 18. If you want to cool a stream between 18C and 5C what cooling medium you can use?
Thank you in advance!
Kind regards,
  • 7,065 posts
Posted 21 July 2018 - 04:39 AM
Let you use your favorite search engine , key word Chiller .
I don't know where you got the information that CW will allow the temperature of system to reach 18C ! It depends very much of the weather condition where the CW is located.
hope this is helping you .
#3 fallah
  • 5,026 posts
Posted 21 July 2018 - 07:06 AM
panoskagiou,
You can apply chilled water produced from the system equipped with mechanical refrigeration...
