Gents,
It seems to be common practice amongst my colleagues that a full bore, ball on/off valve shall not be open before ensuring that the differential pressure between the upstream and downstream side is lower than 15-30 psi. Some colleagues argue that this holds for liquid, but some of them consider this should be followed even for gas at, say, 300 psig (i.e. valve cannot be open until the downstream side is pressurised to 270-285 psig).
What is the rationale behind this? Is it only aimed to prevent oversizing the actuator? Does opening the valve across a large differential pressure creates high vibration or any other operational upset?
Any feedback on this would be deeply appreciated.
Regards.
