Does anyone know if there is a API or industry standard requirement for always having a shut down valve in the outlet of a surge tank with a pump downstream. Thanks
Posted 21 August 2018 - 10:06 AM
Posted 21 August 2018 - 11:47 AM
I recall that API has a recommendation to provide a remote operated valve between the tank and the pump. It depends on the tank volume whether the valve is required or not.
Posted 21 August 2018 - 12:32 PM
chemproc,
Not always required such SDV; it's really required downstream of the tanks containing great volume of flammable liquid to prevent relieving the flammable liquid through the outlet line following to the line failure due to any reason...
Posted 21 August 2018 - 02:23 PM
Thanks Fallah, do you know of any industry standard such as API or other codes that speaks to this issue? Thanks
White Powder Residue After Cleaning Potassium Silicate Tank – Common IStarted by Guest_EunchongLee_* , 16 Apr 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Gas Blanketing Vent Size For Atmospheric Storage TankStarted by Guest_Fergie_* , 13 Apr 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
