Pumps Mechanical Run Test
Posted 15 October 2018 - 02:00 AM
Is it possible to carry out MRT by water service. Or we shall wait and perform it with Naphtha service ???
Is there any criteria of service density range allowing water MRT ???
Posted 15 October 2018 - 05:08 AM
I believe the hydraulic tests of your pumps ( TDH vs Flowrate ) were performed using water . Check the documents that were supplied together with the pumps .
Density is affecting the power consumption .
hope this is helping you .
Posted 15 October 2018 - 05:20 AM
Hello, i am currently commissioning Naphtha hydrotreating unit and i need help regarding Naphtha Pumps mechanical run test (MRT).
In your case the MRT can be done by water...
Posted 15 October 2018 - 05:56 AM
Posted 15 October 2018 - 11:19 AM
What about vibration and temperature ? Would not be high due to water high density (naphtha actual density at some pumps are 550-650 kg/m3)
I think, even if higher density would lead to vibration increment, the vibration level of the test with water should be within the allowable vibration range because almost all pumps should be designed to handle the water without any problem...
Posted 17 October 2018 - 06:51 PM
Did you ask your pump vendor?
Carbon Mol. Seive Mechanical PropertiesStarted by Guest_Ranga v_* , 31 May 2026 |
Process Engineers / Mechanical Engineers - ResponsibilitiesStarted by Guest_PhilippM_* , 10 Jun 2019 |
Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
