Hi!
I need help in how to calculate standard volume of gas needed to pressurize an oilwell from X pressure to Y pressure.
I have made macros to calculate Z- factor and density of the gas by the Soavey Redlich Kwong EOS. I know the temperature gradient of the geology so I know the temperature pretty exact down the wellbore, this is also confirmed by the Downhole pressure and temperature gauge.
The calculated density of the gas is pretty spot on based on pressure measurements from the mentioned Downhole pressure gauge which verifies the calculated hydrostatic pressure exerted by the gas column. The density is calculated for 1000 points down the wellbore, i.e a good representation of the "average" Z- factor/density exists.
The well is initially filled with a brine-based completion fluid, then the well is displaced to pure nitrogen gas by circulating the fluids out of the well by the annular cavity, the wellbore is isolated from the reservoir by a deep set plug which is pressure tested. and the annulus valve is closed and pressuretested i.e:
- There is a certain limited free-gas volume which can be calculated with high precision
- The temperature is known through the wellbore, and the pressure and density is calculated
-The gas stays in the well for a long time, i.e. the gas temperature will be close to the geology temperature, before the gas is bled off through the flare line.
So far all good, my calculations yields high precision until I try to calculate the standard volume of gas needed for the operation.
My macro for calculating standard volume of nitrogen needed:
Function Standard_Gas_Volume(P_initial_Bar, T1_Celsius, V_m3, P_final_Bar, T2_Celsius)
'to calculate a standard m³ of gas that needs to be bled off or added to at pressure containing vessel
'to pressurise or bleed off pressure to P_Final_Bar
'Z values calculated by Soavey Redlich Kwong EOS, output in sm³
'P1_Bar&P2_Bar in Bar
'T1_Celsius&T2_Celsius in Celsius
'V_m3 Volume of the pressure containing vessel in m³
T1_K = Kelvin(T1_Celsius) 'Converts Celsius to Kelvin
T2_K = Kelvin(T2_Celsius) 'Converts Celsius to Kelvin
P1_P = Pressure_Pa(P_initial_Bar) 'Converts Bar to Pascal overpressure
P2_P = Pressure_Pa(P_final_Bar) 'Converts Bar to Pascal overpressure
Z_1 = SRK_N2_Z(P_initial_Bar, T1_Celsius) 'Z factor 1
Z_2 = SRK_N2_Z(P_final_Bar, T2_Celsius) 'Z factor 2
Z_atm = SRK_N2_Z(atm_Bar, T2_Celsius) ' Z factor atmospheric
If P2_P & P1_P = 0 Then
Standard_Gas_Volume = 0
ElseIf P2_P = 0 Then
Standard_Gas_Volume = ((P1_P) / atm_Pa) / (Z_1 / Z_atm) * (T2_K / T1_K) * V_m3
Else
Standard_Gas_Volume = ((Abs(P1_P - P2_P)) / atm_Pa) / ((Z_2 + Z_1) / 2) * (T2_K / T1_K) * V_m3
End If
End Function
Question: I don't seem to get this right, Should I use the average Z-factor of the whole wellbore for both pressures, or the Z- factor of the gas at the "top of the well? I don't seem to get this right.
All help is certainly much appreciated.
Best Regards, Daniel
