I would like to get your feedback regarding whether the code allows to have a link between an ESD trip singal acting on its final SIF elements (SDV) in addition to sending a signal to another DCS pressure control loop to change the controller output to higher opening of a PCV for example. The reason for such a proposal is to help in mitigating pressure build up at the suction of a tripped compressor.
Since control DCS elements are not SIF and hence cannot be SIL assessed, I am doubting whether it is acceptable to take credit for the above described linking action between ESD and DCS.
Appreciate your feedback and views based on your experience.
