Emergency Shutdown Action On A Control Loop
#1 SawsanAli311
SawsanAli311
  • 99 posts
Posted 01 January 2019 - 01:46 AM
I would like to get your feedback regarding whether the code allows to have a link between an ESD trip singal acting on its final SIF elements (SDV) in addition to sending a signal to another DCS pressure control loop to change the controller output to higher opening of a PCV for example. The reason for such a proposal is to help in mitigating pressure build up at the suction of a tripped compressor.
Since control DCS elements are not SIF and hence cannot be SIL assessed, I am doubting whether it is acceptable to take credit for the above described linking action between ESD and DCS.
Appreciate your feedback and views based on your experience.
#2 Bobby Strain
Posted 01 January 2019 - 10:28 AM
Sounds like you are doing something wrong if you need to complete this action.
#3 SawsanAli311
SawsanAli311
  • 99 posts
Posted 01 January 2019 - 12:00 PM
Hi Mr.Bobby,
Actually I have seen this proposal in one of the field modifications proposed for a gas compression plant, In one of the design review workshops , I clearly highlighted that there shall be no signal inter-link between an ESD function and a DCS control loop.. Yet, Contractor stated that this is acceptable, I am highly doubting this I am seeking more views on the subject with specific quotes from the code if anyone has..
#4 fallah
  • 4,954 posts
Posted 01 January 2019 - 12:32 PM
I don't think such a matter being dictated by a specific code and i think it might mostly be mandated by engineering practices rather than the code...
I have seen control valves, say FV, received DCS signal for normal function also equipped with a solenoid valve being activated by an ESD signal in an emergency case and override the flow signal from the DCS to be situated at the relevant fail safe position...
#5 Technical Bard
Technical Bard
  • 407 posts
Posted 01 January 2019 - 07:55 PM
Most owner companies I have dealt with would NOT allow this.  They would require separate sensing devices for the SIF and DCS actions.
