Flow Flashing Through Orifice Formula
#1 anand1194
anand1194
  • 9 posts
Posted 07 January 2019 - 01:46 AM
Can someone please tell me the source of this formula below for flow through orifice in flashing condition? It would be very helpful.
Thank you.
p1 : Primary Pressure (kPa abs) p2 : Secondary Pressure (kPa abs) do : Diameter of Orifice (mm) C : Discharge Coefficient Qw : Water Flow Rate (m³/h) FL : Pressure recovery factor (=0.9) FF : Critical pressure ratio factor P : Absolute vapor pressure of the water at inlet temperature (kPa abs) SG : Specific Gravity
  • 7,039 posts
Posted 07 January 2019 - 02:54 AM
Hi
You may contact TLV for the source , they are using similar equation for water calculation flow rate .
IEC 60534-2-1 ?
good luck.
Edited by breizh, 07 January 2019 - 05:14 AM.
#3 anand1194
anand1194
  • 9 posts
Posted 08 January 2019 - 03:26 AM
Thanks.
