Reflux Drum Design
#1 pdchorai
pdchorai
Posted 21 January 2019 - 06:00 AM
We are currently operating a distillation plant without reflux drum.
But off late, we are unable to achieve the purity within desired time; ultimately resulting in partial charring of material.
We then decided to provide a pre-heated reflux back into the column. For this we need to design a reflux drum. Can any one suggest the best idea?
System specification:
Column lenght: 27 Feet
Column ID: 12"
Column internal: Paul Rings
Kettle: 2 KL Limpet coil reactor.
Vacuum: Double Stage Water ring vacuum pump, with booster.
  • 6,937 posts
Posted 26 January 2019 - 09:57 PM
hi,
It's difficult to understand what you want to achieve . what is the current situation ? one single stage ?
is it a batch process , a continuous process ? any PFD or PID available?
what is the material , what are the impurities ?
what do you expect ?
what do you mean by pre heat reflux ?  do you have a total condenser or a partial condenser ?
thanks to share more information to get meaningful answers.
note : packing should be Pall rings.
good luck
#3 breizh
  • 6,937 posts
Posted 28 January 2019 - 02:42 AM
In addition to my previous answer , you should consider to use your favorite engine search , key words : reflux drum design
Plenty of documents are available there .
