ciamba87, on 29 Jan 2019 - 12:04 PM, said:
Good afternoon, I can't find anywhere the size of an existing air separation process plant, I found a range of 100-5000 tonn/day for production and a range of 15-60 m height and 2-4 m each side for "cold box" dimensions. I didn't find a relationship between these two data. I imagine that it depends on technology and each setup has its own specification but could you provide any reliable example or references?
Thank you,
Alessio
I really can't fathom, how will this data help you. Why on earth do you need this sort of strange data?
I have engineered and operated plants from 50 TPD to 5500 TPD. Each unit having different configurations and thus Cold Box dimensions.
Cold Boxes having Main Heat exchangers inside them will be wider than Plants which have separate MHE Boxes. Columns which are trayed or have top hat columns or collect Liquid Liquid N2 at top of LP Column will have different height, there ain't any thumb rule , all depends on what the process needs and how pipping modelling is done.
Sorry to say, I find this question very non-relevant.
Bodhisatya.
