Sandeep,
if the schematic you shared is actually representative of your HYSYS model then there's a lot of modelling missing in my opinion. My recommendation is for you to first define your system in detail before you start simulating.
Try to model the system as a replica of actual tank operation and control system.
1) The inlet of Inert should be having a PIC and a PV to control the pressure inside the tank. If you do not want the inside pressure to be controlled via a valve, then remove the Inert inlet line altogether and initiate the tank with the composition of your inert gas at the starting of your simulation.
2) Similarly, the outlet line for vapor phase release should either be an PIC controlled PV system to regulate the pressure or it should be an Restriction orifice. The restriction orifice would not prevent back flow and hence it may see negative flow.
3) Liquid inlet flow can be manually controlled by you. However, provide sufficient upstream pressure so that the line does not see reverse flow on opening the valve.
4) Ensure liquid outlet valve is open only when the level is non-zero. Keep a track of liquid level in the tank.
Always keep a track of the pressure inside the tank. Simulator always respects the Pressure-Flow dynamics. The outlet lines battery limit pressure should be low enough to allow forward flow.
Also, keep an eye on the composition of the the liquid. There might be dissolution of vapor phase components in the liquid phase which may cause pressure drop and reverse flow.
Edited by tushargoel, 24 February 2019 - 05:57 PM.
