Flash Point From Heat & Material Balance
#1 sargon 1979
sargon 1979
  • 43 posts
Posted 21 March 2019 - 04:14 PM
Hello everyone
To do hazardous area classification in process plant as mentioned in IP-15 code, it is required to classify each petroleum product according to its flash point, which is usually determined from experiment but, in early days of process plant design, heat and material balance is the only document available which determines the physical properties of petroleum products.
is there any method to predict the flash point using heat and material balance?
is there any method to predict the flash point using Aspen Hysys?
Any help well be appreciated
thank you in advance
  • 6,936 posts
Posted 21 March 2019 - 08:25 PM
Hi Sargon,
Did you check the MSDS ?
another option :
https://dl.uctm.edu/...ova-291-296.pdf
https://www.cheresou...tionestimation/
Edited by breizh, 21 March 2019 - 09:54 PM.
#3 sargon 1979
sargon 1979
  • 43 posts
Posted 25 March 2019 - 06:30 PM
Thank you very much Breizh
It was very helpfull
