Flow Element Sizing
#1 Bodhisatya
Bodhisatya
  • 156 posts
Posted 26 March 2019 - 11:36 AM
Hello All
I have seen two different approaches for sizing orifices/Venturi. While my current organization, sizes it based on BASE CONDITION, my previous employer used "FLOWING CONDITION" to determine Bore size.
Esteemed members requesting an insight, which of the above two methods is more frequently used and Pros and Cons of either sizing methodology.
Bodhisatya
#2 thorium90
thorium90
  • 1,073 posts
Posted 28 March 2019 - 08:24 AM
Although I'm not an orifice sizing expert, but I'm curious, what do you mean by base condition and flowing condition? Isn't the flow element always "flowing" something?
#3 breizh
  • 7,051 posts
Posted 29 March 2019 - 02:37 AM
https://journals.sag...020294014551110
Should be flowing condition , refer to manufacturer data sheet .
Attached a document mentioning flowing condition for all fluid properties.
my view
#4 WyattEng
WyattEng
Posted 10 June 2019 - 03:07 PM
Yes, it should be flowing conditions.  Base conditions are utilized when converting the actual volumetric flow rate (ft^3/min or ACFM, m^3/h, etc.) to an equivalent flow rate under "standard" or "normal" conditions (SCFM, NCMH, etc.), or to convert the actual volumetric flow rate to a mass equivalent.
#5 Chemitofreak
Chemitofreak
  • 292 posts
Posted 11 June 2019 - 12:53 AM
What do you mean by base condition and flowing conditions
