Dear all,
What are the main benefits of the heat pump distillation column? Why to choose a heat pumped column instead of a conventional distillation column?
Posted 29 March 2019 - 03:12 PM
Dear all,
Posted 29 March 2019 - 04:12 PM
The utility costs should be lower for heat pumped column. The equipment is different and the utility savings may justify the difference in the cost of capital.
Posted 29 March 2019 - 05:01 PM
Well! But, we have a compressor, which requires utility (steam or electricity). RIght?
Posted 29 March 2019 - 06:10 PM
http://kchbi.chtf.st...00616X-main.pdf
Plenty of documents on the web .
Consider the link above.
Posted 29 March 2019 - 08:07 PM
Thanks Breizh
![]() Distillation Column Top PressureStarted by Guest_halkeshhulk_* , 27 Jun 2025 |
![]() Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
![]() Distillation Column Top & Bottom TemperaturesStarted by Guest_halkeshhulk_* , 09 Jun 2025 |
Refinery Lpg Deethanizer Column DesignStarted by Guest_Ilyes_* , 15 Feb 2025 |
