Orifice Location
#1 rikakose
rikakose
  • 80 posts
Posted 01 April 2019 - 08:58 AM
we need to modify a piece of the pipe line to use it for pump minimal flow.
There is no much space on the line to add a orifice. The easiest location is at the valve flange.
The valve is a DN80 ball valve. Will there be any risk or bad consequence ?
  • 7,036 posts
Posted 01 April 2019 - 03:34 PM
https://control.com/thread/1026240096
Consider the link above . Refer to the documents attached with installation requirement , for minimum flow the distances may not be necessary , precision not required  .........  others will comment .
my view
Edited by breizh, 02 April 2019 - 12:58 AM.
#3 Chemitofreak
Chemitofreak
  • 292 posts
Posted 02 April 2019 - 03:45 AM
I think your purpose is to kill the pressure and not measure flow on the minimum re-circulation line, hence you should not worry about the minimum upstream and downstream straight length requirement.
#4 rikakose
rikakose
  • 80 posts
Posted 02 April 2019 - 05:59 AM
Many thanks!
