3 Phase Separator/ Decanter In Hysys
hysys separation
#1 SoonEngineer
SoonEngineer
  • 3 posts
Posted 09 April 2019 - 04:19 AM
Hello Engineers,
I need to separate liquid liquid mixture(organic and NaOH&Na2SO4) In aspen hysys,
I have tried but 3 phaseseparator did not separate them and all stream throuhput same location.
if there's anyone knows? Can anyone help me please?
Actually NaOH and Na2SO4 flow just small
#2 PaoloPemi
PaoloPemi
  • 500 posts
Posted 09 April 2019 - 05:24 AM
please do not post on multiple forums...
(probably) you need to select a suitable model (and verify the presence of correct parameters),
there are many versions of Aspen including different packages and I am not sure which package to recommend,
I have a different software (Prode Properties)  for similar mixtures I would consider the CPA electrolyte or similar (complex) thermodynamic models (there are several available in Prode),
with Aspen you may test the E-NRTL or a EOS with complex mixing rules (depending from mixture and operating conditions)
Edited by PaoloPemi, 09 April 2019 - 05:26 AM.
#3 staffel
staffel
  • 31 posts
Posted 09 April 2019 - 09:14 AM
as said it may depend from many causes,
it's difficult to help if you do not provide the composition and the operating conditions...
#4 nasiradio
nasiradio
  • 3 posts
Posted 24 April 2019 - 02:33 PM
Please I have a question relating to the carryover setup for Hysys. Is anyone here to help?
