Insulation Of Fired Heater Stacks
fire heater combustion insulation stack insulation
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 26 April 2019 - 06:40 AM
We are currently working on improving the efficiency of 3 regen heaters (all direct fire heaters). The stacks are not insulated. We are investigating whether we need to insulate them and whether this may improve the efficiency of operation.
What are the parameters that should be considered to decide on the insulation? Any guidance to specific codes/standards or textbooks would be appreciated as well.
Thanks,
Sherif
#2 PingPong
PingPong
  • 1,477 posts
Posted 26 April 2019 - 08:52 AM
Why would insulating a heater stack improve the efficiency of the fired heater?
It would only increase the temperature of the flue gas leaving the stack into the atmosphere.
It would increase the draft of the stack somewhat, so if you would not adjust for that in some way the heater might consequently operate at a higher excess air which would reduce the heater efficiency.
#3 breizh
  • 7,036 posts
Posted 26 April 2019 - 11:16 PM
hi ,
You may find some interest in the papers attached.
hope this is helping you.
Edited by breizh, 26 April 2019 - 11:21 PM.
