How to display Gross Heating Value (GHV) of Natural Gas in Aspen Hysys V11. Thank you
Posted 07 August 2019 - 05:41 PM
Posted 07 August 2019 - 09:17 PM
You should find an answer at AspenTech's support site. Or browse the HYSYS object model. And you can display GHV in the workbook just by selecting it.
Edited by Bobby Strain, 08 August 2019 - 12:14 PM.
Posted 12 August 2019 - 01:56 AM
Hi Mr Strain, I already tray the hysys object model, so the result is empty (Petrol %). thank you for your suggestion
Posted 12 August 2019 - 04:55 PM
The simplest way to get GHV is through the workbook. You can also get HYSYS Stream Reporter from the support site. This gives you lots of properties.
Two Phase Psv Calculation Through Direct Integration As Per Api 520Started by Guest_emma14778_* , 11 Jan 2021 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
