We have Zero liquid discharge evaporator after RO in effluent treatment. No of effects is 3.
In the first effect Delta T maintains 5 to 6 Deg C during normal operation. Often observed this rise to 12 and 13 deg c and comes to normal after few hrs. IAM not able to find the reason. Can any one help me out pl.
Sorry my last post regarding this deleted some how.
High Delta T Between Vapor And Slurry In Evaporator
Started by raghavesh, Sep 24 2019 08:11 AM
Restriction Orifice In Biomass Slurry ApplicationStarted by Guest_Biomass Process_* , 28 Apr 2026 |
Choosing The Right Type Of Evaporator For Removing Hcl From Aqueous SoStarted by Guest_anggara_* , 09 Feb 2026 |
Rising Film EvaporatorStarted by Guest_lanco_* , 23 Jun 2025 |
