I need to design two condensers for the II stage of evaporator and I am wondering how to do that.
One condenser will be used after the second stage of the evaporator and one for non condensable gases connected to the first stage.
I am wondering whether it is possible use counter current flow for the both condensers?
Do you think that can work? Because previously I was making only co current flow vertical condensers? 1 pass
Which condenser type is better A or B? Please see the attached file.
If I will use only co current flow vertical condensers for the evaporators will it work?
Could somebody show me where I can find some information about the vertical condensers?
Thank you very much for help.
Tomasz
Edited by Orzelgorskiego, 04 October 2019 - 09:11 AM.
