hello ,
1- In order to estimate the cement clinker output transported in chain conveyor , i didn't found much information , the only formula given use the amperage as unknown in a parabolic equation ( (a^2)*i + b*i +d ) ( but no information given only constants ) .
so if there exist any relation or technique to do those kind of calculations, please help me .
2- To calculate the clinker output inside the kiln grate cooler , I've found an equation that multiply the grate chamber pressure with the grate velocity :
Clinker output = P° * V / 18 ( 18 is the problem ?????)
so if there are any relation between pressure and output or with those parameters and the ionizing radiation ( rate of counts / second ) or any other factors that leads to the determination of clinker output please share with me your valuable information .
thank you for sharing your valuable time to help us .
Edited by Mohamed cage, 12 October 2019 - 01:11 PM.
