Problem With Heat Exchanger Rating Using Htri Xist
heat exchanger simulation rating htri steam design heat transfer overdesign surface area temperature
#1 abolghasem202
abolghasem202
  • 17 posts
Posted 15 October 2019 - 02:50 AM
Dear all,
I have a problem in thermal rating of a shell and tube heat exchanger using HTRI V7.3. I would appreciate your kind suggestions on my problem.
This exchanger is going to be used for utilizing steam at about P= 44bar and T>400C for heating a process stream from 34C to 232C.
I have run this exchanger in two cases:
Case 1: Inlet steam temperature = 410C.
Case 2: Inlet steam temperature = 415C.
Cold side properties and exchanger geometry are the same for the two cases. The only difference is inlet steam temperature.
Im not expecting to have a significant difference in obtained results for the two cases, e.g. overdesign percent. But HTRI results are so different for the two cases. Some of the HTRI results are:
Case 1: Overall heat transfer coefficient = 469kcal/m2-hr-C, Overdesign=51.39%.
Case 2: Overall heat transfer coefficient = 329kcal/m2-hr-C, Overdesign=3.6%.
Does it really make that much difference to have a steam temperature of 410 and 415C?
Rating results of HTRI for the cases are attached.
Awaiting your kind responses.
Attached File  Case1.jpg   149.48KB   8 downloads
Attached File  Case 2.jpg   151.55KB   5 downloads
  • 1,636 posts
Posted 15 October 2019 - 08:28 AM
The number of baffles is different between the two cases.
#3 abolghasem202
abolghasem202
  • 17 posts
Posted 16 October 2019 - 08:31 AM
Thanks for the reply.
However, but in my attached images, the baffle spacing and tube length are the same for the two cases. So, I would expect the same number of baffles.
#4 Pilesar
  • 1,636 posts
Posted 16 October 2019 - 10:30 AM
Case 1 has twice the number of baffles of Case 2 despite your expectations. Count them.
