Industrial Waste Heat
#1 Noran Shedid
Noran Shedid
  • 19 posts
Posted 17 October 2019 - 12:14 PM
Where can I find information regarding the amount of industrial waste heat (per plant) released from the different chemical industries? and how much electricity can they generate if recovered?
I will be using ORC (Organic Ranking Cycle) in the conversion of heat to electricity. The cycle will be designed and optimized later on.
Edited by Noran Shedid, 19 October 2019 - 03:20 AM.
  • 1,696 posts
Posted 17 October 2019 - 12:31 PM
An internet search for 'chemical industry energy efficiency' would be a good starting point. What method would you use to convert waste heat into electricity? Not all waste heat is usable and there are additional inefficiencies in electricity generation. Supply the full details of your research topic and you may get more hints.
#3 breizh
  • 7,062 posts
Posted 17 October 2019 - 06:27 PM
https://www.energy.g...Feb-13-2015.pdf
You may consider the link above to start with, many more using your search engine .
https://www.energy.g...rial waste heat
a lot of stuff available in this site .
Edited by breizh, 17 October 2019 - 08:41 PM.
