2
Electric Heat Tracing—Pipe-Wall Temperature Vs. Actual Fluid Temperatu
tracing heat trace
#1 zamakaze
zamakaze
  • 14 posts
Posted 20 September 2026 - 10:17 PM
Hello
I would appreciate clarification on what “process temperature maintenance” means when specifying electric heat tracing.
Consider a water-saturated gas entering a pipe at 35°C, with a water dew point of 35°C at the inlet pressure. If the specified heat-tracing maintenance temperature is 35°C:
  1. Does this refer to the pipe outer-wall temperature or the actual bulk fluid temperature? Does maintaining the pipe wall at 35°C ensure that the fluid remains at this temperature?
  2. As the gas flows, it may cool due to ambient heat losses and the Joule–Thomson effect as pressure decreases. Can heat tracing prevent water condensation under these conditions, considering that the dew point also changes with pressure? Would additional tracing duty or a temperature margin above the dew point be required?
  3. Is tracing for temperature maintenance primarily intended to keep stagnant fluid warm when flow stops, or is it also designed to maintain fluid temperature during continuous flow?
  4. What triggers the tracing to operate? Is it typically controlled by a sensor on the pipe wall beneath the insulation? How does this differ for self-regulating tracing?
  • 7,064 posts
Posted 20 September 2026 - 11:37 PM
The objective is to compensate heat losses.
All refer to outer wall, no contact with the fluid.
As the fluid flows, it will lose some heat.
Heat tracing is for liquid, it does not concern phase change, too much energy required.
Check the specific heat of the gas, it does not favor heat transfer.
Talk to company like Thermon or others to get a proper answer:
Thermon | Industrial Heating Solutions
Chromalox | Pioneering Sustainable Heating Solutions
