4
Hydrate Temperature Prediction Calculator
calculator hydrate
#1 Wayne
Wayne
Posted 19 August 2026 - 11:55 AM
See below for a calculator which predicts the hydrate formation temperature of natural gas systems. Sharing in case someone needs it
Attached File  Hydrate_Prediction_Calculator_Wayne Gajadhar.xlsx   128.5KB   14 downloads
Edited by Wayne, 19 August 2026 - 11:56 AM.
  • 7,060 posts
Posted 19 August 2026 - 11:32 PM
Thanks for sharing.
#3 Pilesar
  • 1,695 posts
Posted 20 August 2026 - 06:37 AM
Very Interesting! Have you compared your results to the hydrate predictors in the top commercial process simulators? I never found a method I trusted completely. I think the biggest problem I had was accounting for the effects of individual components other than the simplified component lumping. In designing process temperatures, I tried to err on the conservative side by using more than one prediction method. In diagnosing plant problems for suspected hydrate formation, it was difficult to completely trust any calculation result that gave assurance the temperature was above the hydrate formation temperature.
#4 Pilesar
  • 1,695 posts
Posted 20 August 2026 - 07:04 AM
An additional feature you may want to incorporate in your spreadsheet is to include the reference citation for the methods you are implementing.
For additional comparison, see the spreadsheet contributed by Ankur (who used to be quite active here.)
Four methods for hydrate prediction are compared in that spreadsheet.
This is the link:  Hydrate Formation Temperature - Cheresources.com Community
#5 mattb
mattb
  • 10 posts
Posted 20 August 2026 - 09:20 AM
Thanks for the contribute,
You may consider also online calculators to verify your results
https://www.prode.co...ies/hydrate.php
#6 breizh
  • 7,060 posts
Posted 21 August 2026 - 06:51 AM
Other resources available
Gas Hydrate Formation Temperature Prediction In Hysys - Chemical Process Simulation - Cheresources.com Community
Dissertation_14689.pdf
#7 Wayne
Wayne
Posted 31 August 2026 - 07:50 AM
Thanks all for the comments. I developed this tool to determine the impact of H2S on the hydrate formation temperature after observing my gas injection chokes being plugged. The results are a good estimate regarding the relationship however the chemical vendor and specialist should be consulted as part of the treatment program.
Edited by Wayne, 31 August 2026 - 07:51 AM.
